Archived
Better Handling of DateTimes on FME Cloud
  • Dec 28, 2020 8:20 PM UTC
  • 31 views
dbaldacchino1
Forum|alt.badge.img+14
This post explains the issue in detail. Dates from FME Cloud are returned in UTC and you have to customize a workspace and associated functions to convert the time to the required zone. The handling of datetimes should be improved so the posted solutions (which I feel are a bit convoluted, especially the first one) are not required.
dbaldacchino1
  • Dec 28, 2020 8:27 PM UTC
Forgot to add that while it does make sense to perhaps use UTC for FME cloud since the instance can be in a different timezone, the resulting current datetime behavior is not consistent with FME Server.
