Archived
Best Practices for having multiple versions of FME Desktop installed
Related products:FME Flow
  • April 21, 2017
  • 67 views
Particularly relating to licensing, what is the default version, and managing python interpreters/packages/etc.
erik_jan
Forum|alt.badge.img+26
  • April 21, 2017
I have multiple versions of FME Desktop installed and use a lot of batch files.
I always use the full path to the FME executable in the batch files to avoid using the wrong FME version.
Forum|alt.badge.img+63
If you set the relevant option during the install process the last installed version will grab the Windows file associations (so doubleclicking a .fmw file in Explorer will open the last Workbench version you installed). Just to be on the safe side I right-click and go through the "Open With" list)
