Open
Be able to use a web connection in ArcPy
Related products:Integrations
  • Jan 31, 2025 3:26 PM UTC
  • 5 replies
  • 157 views
germang
Forum|alt.badge.img+16
It would be nice to be able to use ArcGIS web connection to authenticate processes when using the ArcPy library
LizAtSafe
Forum|alt.badge.img+26
  • Apr 29, 2025 3:55 PM UTC
New→Open
bruceharold
Forum|alt.badge.img+19
  • Aug 12, 2025 8:08 PM UTC
Hi ​@germang Can you describe the processes you want to run?  Thanks.
germang
  • Aug 13, 2025 7:25 PM UTC
We want to perform a few geoprocessing tasks not possible with just FME Transformers.
Two examples:
Overwrite a geocoding service
Create a vector tile and then use Replace Web Layer
bruceharold
  • Aug 5, 2026 2:25 PM UTC
​@germang Did you make any progress on this, say by using the argis module?
germang
  • Aug 10, 2026 7:05 PM UTC
I had to use other authentication methods, but they are hardcoded in the Python code.
It would be much preferable to be able to use traditional FME web connections instead.
