Archived
Backup/Restore FME Options Configuration
Related products:FME Form
  • Dec 11, 2018 12:00 AM UTC
  • 7 replies
  • 174 views
It would be convenient when moving FME Desktop installation from an old machine to a new one if there was a functionality to backup/restore FME Options configuration, especially regarding Database/Web Connections.
ekkischeffler
Forum|alt.badge.img+7
This could also restore the way I've trained my FME Desktop to suggest transformers when typing in the canvas.
gabriel_hirsch
Forum|alt.badge.img+15
Good idea. I used to solve this by creating a workspace that moves info from one FME installation to another when installation a new FME version on the same machine. So you could solve this task in the same manner collection files in to a zip-fil and then a workspace that move the files to the correct locations on the new machine.
(the db connections are store in a SQlite database found here (or where you have set your default path): C:\\Users\\user_name\\AppData\\Roaming\\Safe Software\\FME\\fme_connections.data)
chriswilson
Forum|alt.badge.img+29
  • Jan 8, 2019 9:01 PM UTC
How did you do that Ekki?
  • Dec 18, 2019 3:44 PM UTC
It seems to be possible to simply export and import data connections, using 2019.1
Select the connections you want to export and right-click to export.
davideagle
Forum|alt.badge.img+21
  • Mar 16, 2020 3:10 PM UTC
Regularly get asked if this is possible when I'm training organisations who have a few licences or are using floating licences. An export would be really useful rather than having to just export parts bits at a time, such as just bookmark styling and then digging around to pickup the database connections file. Puts me in mind of an FME Server backup but with the ability to chose what part to export and what to import back. Also, similar to this requirement https://knowledge.safe.com/idea/109824/ability-to-reset-all-workbench-settings-to-factory.html?.
nic_ran
Forum|alt.badge.img+20
  • Jun 19, 2020 4:00 PM UTC
FME does that automatically but that information does not get "remembered" for new installs.
LizAtSafe
Forum|alt.badge.img+26
  • Sep 2, 2025 9:56 PM UTC
Updated idea statusOpen→Archived
Idea merged into:
All the votes from this idea have been transferred.
