New
Automation App: Improve display of Automation Trigger
Related products:FME Flow
  • Nov 24, 2026 8:38 AM UTC
  • 0 replies
  • 15 views
jmiddel
Hi Safers,
I would like to suggest an improvement to the Automation App UI.
If I want to trigger an automation via the app, the only indicator that the automation was triggered is the green pop-up in the upper-right corner. I tested this in FME 2026.3.1.1, but it shows the same behaviour in previous FME versions.
This pop-up disappears after some time, and the user is still able to trigger the automation again. The UI needs to be improved because this can lead to a user unintentionally triggering the automation a second time.
Please improve the app’s UI. For example, the information about the successful trigger event could remain visible in the middle of the page, and/or the Run button could be removed and replaced with a “Run Again” button.
It would be good to have the same UI as in FME Workspace Apps.
Best regards,
Jan
