Open
Autodesk CS reading
Related products:Integrations
  • February 23, 2021
  • 0 replies
  • 12 views
gisbradokla
Forum|alt.badge.img+27
when reading autodesk dwg files there are several potential sources (see below) for transformation/projection definition. Please make these more defined and possibly allow selection of the source. Also if this were a format attribute that allow validation at read.
  1. AutoCAD Map3d CS definition
  2. AutoCAD transformation
  3. Esri assigned transformation
  4. prj file
I have found files with 2 differing projections assignments and fme has a non-setting default assignment to the esri assigned projection. This is not documented and not even something that can be changed. without knowing what it is doing and over-riding it.
