Archived
Auto Workflow Optimizing (Merging Transformers)
Related products:Transformers
  • Feb 16, 2016 12:00 AM UTC
  • 5 replies
  • 86 views
Logical and Performance Optimizing Concept: Similar to finding the shortest(Best) path
1 Map out the logic of all the transformers. (map creation)
2 Detect unnecessary logic steps. (shortest path calculation)
3 Merge transformers without breaking the logic. (shortest path implementation)
3.1 Merge multiple adjacent Testers into one Tester or TestFilter
3.2 Merge multiple adjacent AttributeManipulators into one AttributeManager
3.3 Replace (Bufferer+Dissolver) with AreaAmalgamator or vice versa
3.4 Replace PointOnLineOverlay with SpatialFilter or vice versa
3.5 Replace AttributePivoter with Aggregator or vice versa
3.6 ...
jdh
Forum|alt.badge.img+41
  • Feb 16, 2016 9:36 PM UTC
The number of times I have a several testers that I later decide need to be a testFilter instead...
fmelizard
Forum|alt.badge.img+22
  • Feb 17, 2016 5:54 AM UTC
To be clear, is this to merge adjacent Testers into a TestFilter? Not sure what other transformers can be merged? (Testers->TestFilter is a great idea by the way)
  • Feb 17, 2016 7:33 AM UTC
I mean I want to conbine the test conditions(AND,OR)from two testers, I only need one output.
AttributeManager, maybe?
jdh
  • Feb 17, 2016 2:46 PM UTC
The original idea was multiple testers to one tester, I hijacked the idea to make it multiple testers to one test filter (one output port per original tester)
  • Feb 17, 2016 3:05 PM UTC
Could be nice if They can implement both Options,let the user decide to merge them as Tester or TestFilter.
