Archived
auto-flush CSV files after stopping workspace
Related products:Integrations
  • September 8, 2016
  • 66 views
Following this question csv flushing it has been suggested that the FME CSV writer should auto-flush the writes following a manual cessation of the workspace.
  • September 8, 2016
Agreed. I think this would be a good idea for both the CSV and Text File writer.
mark2atsafe
Forum|alt.badge.img+59
  • September 8, 2016
I'm not sure we would auto-flush those formats. Seems to me that in most cases if I stop a workspace it's because I *don't* want to write any data. Or at least, if we did add this it would be optional. Maybe we add a "Transaction Interval" parameter to the CSV writer, although it would need to be in Append mode for that to make sense.
  • September 8, 2016
Yes I agree - it could be an option to autoflush if workspace is manually stopped.
As identified above, there's at least one situation where I *do* want to the write the data when stopping the workspace (i.e. the TweetStreamer).
I've noticed that when there are more than one CSV writers in a TweetStreamer workspace, and I stop it after half an hour, the second CSV file has been 100% buffered and *nothing* has been written (not even the empty file).
This also has further implications - I have seen colleagues sequentially process substantial datasets and everything on the second CSV file appears to be buffered. Two problems exists here:
1) massive RAM consumption results.
2) when testing a workspace it's common to run for a small amount of time and stop it to check the results. Can't do that if nothing is written and the buffer has not been flushed.
