Open
AttributeValidator: localizable messages
Related products:Transformers
  • Feb 25, 2016 12:00 AM UTC
  • 49 views
The AttributeValidator currently outputs the results in English. Since it is sometimes necessary to provide localized or custom messages, I suggest that the AttributeValidator include "message numbers" in addition to the full message, much like Oracle does with error messages (ORA-nnnn):
Currently: Attribute 'abc' with value 'a' fails check for Type is 'INT'
Suggested: Attribute 'abc' with value 'a' fails check for Type is 'INT' (FME-AV-1234)
Where 1234 would be a unique integer that identifies the message.
To translate, one could then search for FME-AV-nnnn rather than a specfic wording interspersed with attribute names etc.
geosander
Forum|alt.badge.img+7
  • Feb 25, 2016 4:43 PM UTC
In general, I think error codes would be a good idea!
fmelizard
Forum|alt.badge.img+22
  • Feb 25, 2016 5:01 PM UTC
We've been trying to do this with the <Rejected> ports and the fme_rejection_code -- standardize on a small set of codes that are at least largely consistent and potentially localizable. Doing a similar thing for AttributeValidator is not a bad idea at all.
djmcdermott
  • Mar 10, 2016 3:23 PM UTC
I have started looking at the Attribute Validator following the How to Optimize GIS Workflows webinar. I agree that an additional column to provide custom error messages/codes would be very useful. It would allow me to use a TestFilter to split the errors into separate workflows.
Additionally, it could have the option to expose the validation as separate output....
davtorgh
Forum|alt.badge.img+12
  • Dec 22, 2020 3:05 PM UTC
As stated by @djmcdermott, an additional column to provide custom error codes would be very useful. With an AttributeValueMapper, for example, error codes could be used to give back localized or custom messages read from a lookup table.
