Archived
AttributeValidator: link validation to schema of a writer
Related products:Transformers
ekkischeffler
Forum|alt.badge.img+7
Add a function to the AttributeValidator to dynamically link it to the attribute schema settings of a writer. I.e. if the linked writer has an attribute called 'Name' which is a 50 char type attribute, all attributes longer than 50 characters will fail the AttributeValidator. This will help ensure that the validated data matches the output schema and does not make the workspace fail due to e.g. writing a string into an integer field.
