Open
AttributeValidator - Composite tests
Related products:Transformers
todd_davis
Forum|alt.badge.img+23
Can the attributevalidator be made to allow for composite tests....e.g. Field type is Double but null is also possible.
revesz
Forum|alt.badge.img+22
  • June 20, 2016
I miss 2 options that would make AttributeValidator much more powerful:
  • contain the substring (where the substring could be a regexp) rule,
  • checkbox to negate rule
But would be great to have the flexibility and options as in TestFilter.
By the way, is it a good idea to put AttributeValidator and TestFilter together, and use a checkbox for selecting to create ports for each rejection or reject at the end with a list of the unmatched rules?
oscard
  • February 6, 2020
I have faced a couple of workspaces where this enhancement of the AttributeValidator would have been very useful!
Forum|alt.badge.img+54
  • August 11, 2020
Just the ability to choose whether empties/missing/null can be passed alongside an additional test would be useful, even if more complicated conditional tests weren't possible.
thijsknapen
Forum|alt.badge.img+12
Besides the idea @jlutherthomas linked to, this idea also seems to be linked to this idea: https://community.safe.com/s/idea/0874Q000000j0G6QAI/detail
ltwigg
Forum|alt.badge.img+3
  • December 5, 2022
I've built a BulkAttributeValidatorWithMapping, takes external configuration file like SchemaMapper, allows logical testing like Tester (including NOT), can group tests together (composite tests - eg "Attribute A is a number, or Attribute A is blank"; or... "Attribute A is ABC or Attribute B is DEF"), and custom error messages can be entered (each failed test is concatenated onto an error string). It works with un-exposed attributes (designed to work with an upstream SchemaMapper). May take a while to run as it checks each feature against each validation rule.
If anyone is still following this thread and is interested, I'd appreciate any feedback.
  • February 28, 2023
How is this still not possible?
LizAtSafe
Forum|alt.badge.img+25
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
LizAtSafe
LizAtSafe
