When using the AttributeManager I think an enhancement would be if the possible actions should start with a distinctive letter (eg "Set Value", "Leave or Ignore" (for Do Nothing), "Rename", "Forget" (for Remove), "Default" (for Set Default Value) so that one can select and then easily act by hitting a single key.
