Archived
AttributeManager: automatically update 'Do Nothing' attributes
Related products:FME Form
  • Jun 15, 2016 12:00 AM UTC
  • 10 replies
  • 93 views
ekkischeffler
Forum|alt.badge.img+7
The AttributeManager accounts for all attributes, including those without action. If I remove an attribute that is listed in a following AttributeManager, the transformer turns red, indicating an error. This should be ignored for all 'Do Nothing' and 'Remove' attributes - the list of attributes in the AttributeManager should simply be updated.
Agreed. Good Catch! I've filed a request to fix this.
ekkischeffler
  • May 25, 2017 5:28 AM UTC
I have one more thing to add to this: At the moment all attributes within an AttributeManager are subject to workspace search, including do-nothing attributes. This means that the search for an attribute will list mostly all AttributeManagers even if no action is applied to it. This is rather confusing as I'm usually interested in where attributes change. I would suggest to exclude all do-nothing nothing attributes in an AttributeManager from the workspace search.
ekkischeffler
ekkischeffler
ekkischeffler
Another note on this - all attributes listed in the AttributeManager are subject to workspace search, even those I do nothing with. This is slightly confusing when searching for a certain attribute as the search will list all AttributeManagers although the do nothing attributes are only carried through without action. Therefore I think that do nothing attributes should also be excluded from the workspace search.
lottegis
  • May 26, 2017 5:03 AM UTC
Great suggestion. AttributeManager will be less annoying to use when a workspace is still being developed with attributes still being determined.
  • Jan 22, 2018 3:37 AM UTC
I'm finding AttributeManager almost impossible to use as I work on a REST/JSON-related development due to these downstream errors. But I still need to modify properties...
tijs
Participant
  • Participant
  • Aug 20, 2019 2:24 PM UTC
I'm still experiencing this in 2019.0
tijs
Participant
  • Participant
I'm still experiencing this in 2019.0.
itay
Forum|alt.badge.img+19
  • Aug 21, 2019 12:07 PM UTC
You have my vote!
