Open
AttributeHider
Related products:Transformers
  • Nov 3, 2015 12:00 AM UTC
  • 10 replies
  • 158 views
jdh
Forum|alt.badge.img+41
The opposite of the attributeExposer. Sometimes I need to temporarily expose an fme_attribute in order to preserve it's value (ex. LineJoiner) or replace it's value (ListIndexer), but would rather not have it trailing through the rest of the workspace, especially when this takes place within a custom transformer.
  • Nov 3, 2015 11:00 PM UTC
Agreed. I also hope that.
fmelizard
Forum|alt.badge.img+22
  • Nov 4, 2015 3:52 AM UTC
We've been talking about adding this into the new AttributeManager at some point.
In teh meantime, you can put down a PythonCaller -- by default it does nothing -- and you can use its "hide attributes" to accomplish what you want. Awkward and annoying I know. But at least you can do it already.
  • Nov 4, 2015 3:59 AM UTC
If so, how about adding both "Expose" and "Hide" to the AttributeManager?
thijsknapen
Forum|alt.badge.img+12
  • Aug 2, 2023 9:25 AM UTC
Too bad that it hasn't made the cut in the past 8 years. I wanted to post exactly this idea today. You got my vote!
I know you can use a PythonCaller or TCLCaller as a workaround, but it doesn't feel ideal. Also, isn't it the case that using a PythonCaller (by default) would break bulk mode? That, next to loading in dlls (packages/modules) don't feel to be neccessary for what we would like to achieve.
LizAtSafe
Forum|alt.badge.img+26
  • Apr 5, 2025 4:13 AM UTC
Open→Archived
arthur_bazin
Forum|alt.badge.img+19
  • Oct 28, 2026 7:46 AM UTC
​@LizAtSafe is it definitly Archived ?
I have about ten cases where I need to hide attributes. A majority comes from the output of a custom transformer where I want to keep the data but don’t want to expose it so the main workspace stay clean.
When you have a lots of transformers (100+) one new attributes or one less and you have to change the configuration of plenty of attributeManager (not always but in some case you have to).
For me that could be far greater than using the PythonCaller
PierreAtSafe
Forum|alt.badge.img+11
Hi ​@arthur_bazin ,
It’s been archived as the Idea was pretty old with no recent activity / evidence of interest. I’m happy to bring it back for consideration if you believe this could still be a good improvement to FME!
arthur_bazin
I'm using plenty of PythonCaller to hide my attributes so you can consider that this would be a really great improvement to FME !
Thanks !
PierreAtSafe
I’ll re-open this Idea, see if it attracts a bit more attention then!
PierreAtSafe
Updated idea statusArchived→Open
