Released
AttributeExposer - Trim When Importing Attributes
Related products:Transformers
  • Jan 25, 2024 1:00 AM UTC
  • 67 views
chriswilson
Forum|alt.badge.img+29
Have just come across an issue importing attribute names using attribute values from an Excel spreadsheet. A whitespace is somehow being added after the value that is imported, in some cases, even when I go and manually trim the attribute values in the spreadsheet beforehand.
Adding an option to ensure whitespace is trimmed from attribute names or values that are being imported into the AttributeExposer could be a useful option to ensure that attributes are imported as desired without the additional whitespace.
LizAtSafe
Forum|alt.badge.img+27
  • Apr 5, 2025 4:13 AM UTC
Open→Released
LizAtSafe
  • Apr 5, 2025 4:16 AM UTC
When adding an Excel Reader, in the parameters, under Advanced, there is a parameter called Trim Whitespace from Attribute Names which is enabled by default.
