Gathering Interest
Attribute manipulation on lists
Related products:Transformers
  • Mar 17, 2016 12:00 AM UTC
  • 5 replies
  • 143 views
jdh
Forum|alt.badge.img+41
There are several situations where I would like to use a transformer that manipulates attributes on every element in a list. The current option is to explode the list, do the manipulation and then reconstitute the list, which is inefficient (introduces blocking transformers) and can cause issues with the geometry of a feature, create a looping custom transformer with a listIndexer for every element in the list, or alternatively code the list manipulation in python. It would be nice if the following transformers could work on lists.
Manipulates the attributes directly:
AttributeTrimmer
StringCaseChange
StringFormatter
DateFormatter
StringPadder
Creates parallel structure list:
AttributeValueMapper
FilenamePartExtractor
StringConcatenator
SubstringExtractor
i'm sure there are other transformers that would benefit from this as well.
erik_jan
Forum|alt.badge.img+26
  • Mar 17, 2016 2:58 PM UTC
Like the AttributeManager, but then for list manipulation. So I would call it the ListAttributeManager.
fmelizard
Forum|alt.badge.img+22
  • Mar 18, 2016 4:55 AM UTC
If we could make the places that accept a set of attribute names also accept an unqualified list (i.e. someList{}.anElement or someList{} ) , I suspect this would do what is desired here. Good suggestion.
tomf
Forum|alt.badge.img+31
  • Oct 5, 2018 2:29 AM UTC
Adding the AttributeRounder to the list ...
(And bumping the idea up!)
andreaatsafe
Forum|alt.badge.img+17
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • Mar 9, 2026 4:31 PM UTC
Open→Gathering Interest
