Archived
Attribute Manager Actions - Colour Code or Icons
Related products:FME Form
  • November 30, 2016
  • 10 replies
  • 69 views
fmelizard
Forum|alt.badge.img+22
Using the AttributeManager some users have reported that it is hard to tell the different Actions apart and colour coding or icons might help. If you agree please up-vote or if you have a better idea please comment.
  • December 1, 2016
I'd prefer to be able to sort the attribute list on an arbitrary column, but in particular on the Action column.
courtney_m
Forum|alt.badge.img+23
  • December 1, 2016
I agree with @david_r. I think being able to sort the attributes by Action would be more helpful than color-coding.
fmelizard
  • December 2, 2016
Yes for sure good idea, this ordering of columns is Safe PR#67953
fmelizard
  • December 2, 2016
Ordering of columns in the AttributeManager has been posted as an Idea here if anyone wants to vote for it and also we have it as Safe PR#67953
https://knowledge.safe.com/idea/27703/sort-by-attribute-name-in-attribute-manager.html
revesz
  • December 5, 2016
I strongly back the idea. The neighbouring if 'Set Value' tend to also change to Set Value. It ends up emptying columns which is hard to track down in a larger workspace. Different colours would be a big help to spot out these accidental changes at the first place.
jdh
Forum|alt.badge.img+41
  • December 9, 2016
As long as the sort was visual only, and not affect the order the actions are taken in. I have a lot of situations where there is an interdependence among the attributes.
ie create attribute A as a conditional expression using Attribute X
create attribute B involving A and Y
delete Attribute X
scyphers
Participant
Forum|alt.badge.img+5
  • Participant
  • January 17, 2017
A very handy trick would be able to toggle the visibility of the "Do Nothing" Actions in AttributeManager between on/off (hide/display). We typically are only reshaping one, two or okay alot of attributes but we only revisit those subset of fields.
You might need to expose the attr{order} or grey the field ordering buttons, but I would like to sort as david suggests or hide the unmodified from AttrMgr pane.
lifalin2016
  • January 19, 2017
He he, I just suggested the same two improvements (color coding and sorting), having not seen this post (didn't show when I searched). Go team! :-)
Forum|alt.badge.img+54
  • January 19, 2017
Hiding "Do Nothing" attributes would be my number one change. When dealing with features with a large number of attributes I often avoid the AttributeManager as it becomes difficult to see what the transformer is doing.
  • January 19, 2017
I agree wholeheartedly. This is the number one reason for me currently not using the AttributeManager at all.
