Open
Attach a role to API
Related products:FME Flow
philipv
I would like to be able to attach a role to an API token rather than having to rebuild all the permissions directly on the token.
nathanatsafe
Forum|alt.badge.img+9
Updated idea statusNew→Open
nic_ran
Forum|alt.badge.img+20
  • June 5, 2026
I was just about to create this same idea!
We have multiple FME Flow Apps that require the same set of permissions. Having to manage each App’s permissions individually is tedious and error prone. It would be really helpful to be able to assign an API Token to a role so that permissions could be managed in a central and consistent manner.
j.botterill
Forum|alt.badge.img+69
As of FME Flow 2026.1, Flow App API token dependencies are being removed and replaced by a tokenless model
Managing Flow App Permissions in FME Flow 2026.1 or Newer – FME Support Center
So as long as the Owner of the Flow app, has those Role permissions, which it no doubt will… then this request is no longer relevant
philipv
  • June 8, 2026
When I opened this thread, I wasn’t even concerned about Flow Apps.  I am using these tokens for API access.
But the same concern applies to App permissions - we should be able to assign a role.
