Archived
Annotations on a connection should not be deleted when the connection line is in
Related products:FME Form
  • July 10, 2018
  • 0 replies
  • 23 views
jdh
Forum|alt.badge.img+41
***Note from Migration:***
Original Title was: Annotations on a connection should not be deleted when the connection line is interrupted.
Currently if you have an annotation on a connection line and add a new transformer along the connection line, then the annotation is deleted.
Ideally the annotation should be attached to one of the new connection lines, depending on whether the transformer is inserted to the left or right of the annotation tie point.
To keep the annotation now, you have to detach it, insert you transformer and then reattach it, but when you have an eloborate workspace with dozens or hundreds of connections, it can be difficult to find and select the right connection in the drop down list.
