Released
AnchoredSnapper - make vertex snapping optional while snapping segments
Related products:FME Form
  • Apr 12, 2016 12:00 AM UTC
  • 93 views
ngoorman
Forum|alt.badge.img+3
Right now, selecting Segment Snapping while using the AnchoredSnapper means that candidate features will also be snapped to line segments within the specified tolerance. However, candidates will also still be snapped to vertices, and the AnchoredSnapper even prefers vertices to segments, even in Segment Snapping-mode.
My use case is that I need to snap certain features to the closest point on a line. However, in some cases there is a vertex nearby that is not the closest point, but still within tolerance, and the AnchoredSnapper prefers these points. I can probably find some workaround, but a simple checkbox to force the AnchoredSnapper not to snap to vertices but only segments would be a cleaner solution.
  • Aug 9, 2016 2:27 PM UTC
yeah I've found this to be a problem too, causing degenerate geometries as both points are snapping to the same vertex instead of the nearest bit of segment. Would appreciate this addition to the anchored snapper
fmelizard
Forum|alt.badge.img+22
  • Oct 25, 2017 8:14 PM UTC
Hi @ngoorman, I'm pleased to let you know that in our FME 2018.0 Betas you can use the AnchorSnapper to snap to segments even if the vertex is within the snapping tolerance. You can set the transformer to use "Segment Snapping". Give 2018.0 Beta a try if you can.
tomw202
Forum|alt.badge.img+4
  • Apr 13, 2018 2:49 PM UTC
Great that this is sorted in 2018. I'm sure there was a logical reason for prioritising vertices over segments, even in segment snapping mode, but it was an annoying feature!!
tomw202
  • Apr 16, 2018 9:01 AM UTC
Maybe slightly premature with that comment. Tried in 2018 but still snapping to vertices..
