Archived
Allow VertexRemover to accept multiple vertex index values
Related products:FME Form
  • Jun 27, 2018 12:00 AM UTC
  • 31 views
taojunabc
Participant
The current VertexRemover only accepts one vertex index value. If you need to delete multiple discrete vertices, you must use VertexRemove multiple times. I want to specify multiple vertex index values, such as separating them with commas.
taojunabc
Participant
  • Participant
  • Jun 27, 2018 4:11 AM UTC
And deleting a vertex causes the index of the remaining vertices to change. When using VertexRemover multiple times, the new index value that needs to be deleted must also be recalculated. This is very tedious.
