Released
Allow testing against an array of values - new operator "In Array"
Related products:Transformers
  • Jul 29, 2016 12:00 AM UTC
  • 5 replies
  • 55 views
roland
Participant
it'd be helpful to make testing of text values more easy with a new operator that allows tests against an array/list of values with the functionality of the operator "contains". it'd save a lot of test clauses like shown in the example below
  • Jul 29, 2016 12:18 PM UTC
Have you tried using the "In" operator:
It should do what you're asking for.
fmelizard
Forum|alt.badge.img+22
  • Aug 6, 2016 8:00 PM UTC
Yes, "In" Should do as desired here. @roland do let us know if it misses the mark.
roland
Participant
  • Participant
  • Sep 8, 2016 2:09 PM UTC
hallo dale, hallo david,
thanks for your feedback, i know the "in" operator, but it doesn't work with text values as i wish! i mentioned obove the new operator should work like the "contains" operator as my left value "strecke" looks like -> a12, s12, b12, c12, a10, s10, b10, c10, t25, s25, b25, c25 .... and i want to filter all text values that contains [12,10,25,96,26]. i hope my question is more clear now, may be i didn't explain it detailed enough.
Forum|alt.badge.img+54
  • Sep 9, 2016 8:23 AM UTC
Agree that this would be useful, or the ability to use a wildcard with the In Operator.
In the past I have manipulated the left value before testing with the In Operator for this sort of scenario
e.g.
  • Sep 10, 2016 2:53 AM UTC
Hi @roland, in this case, the 'Contains Regex' operator might help you. e.g. the following regex filters text values that consist of a non-digit character and [12, 10, 25, 96, or 26].
  • Operator: Contains Regex
  • Right Value: ^[^\\d](12|10|25|96|26)$
