Open
Allow Job Queue Selection via Parameter in Automation “Run Workspace” Action
Related products:FME Flow
  • June 11, 2026
  • 28 views
some.one.else
Participant
Currently in FME Flow Automations, when using the “Run Workspace” action, the job queue must be selected from a fixed list of predefined queues. There is no ability to dynamically select the job queue using a published parameter or automation attribute.
This enhancement proposes adding support for parameter-driven job queue selection, allowing users to pass a value (e.g., from an automation attribute or published parameter, etc.) to determine which job queue is used at runtime.
nathanatsafe
Forum|alt.badge.img+9
Updated idea statusNew→Open
