Released
Allow Dataset Fanout to Create Multiple Zip Files
Related products:FME Form
  • Nov 8, 2015 12:00 AM UTC
  • 7 replies
  • 92 views
Currently the Dataset Fanout cannot create multiple zip files. A workspace with this setting will archive all destination files into a single zip file, even if the value of "_fanout" varies depending on the features. Hope FME will do fanout zip archiving.
fmelizard
Forum|alt.badge.img+22
  • Nov 9, 2015 5:01 AM UTC
Definitely seems likea bug. I'll file it. See my full example attached -- I'd expect 4 zip files and not one once we're done executing.
badzip.fmw
  • Nov 9, 2015 5:12 AM UTC
I don't consider it as a bug since this restriction is documented clearly.
"Note: You cannot create multiple zip files using Dataset Fanout (therefore, you cannot set the Fanout Suffix parameter to .zip)." -- Writing to a Zip File
My request is to remove the restriction ;)
fmelizard
  • Nov 10, 2015 4:44 AM UTC
The Dev team advises they've fixed this today. I'd look for it in a 2016.0 beta late this week or early next.
  • Nov 10, 2015 5:00 AM UTC
It's awesome! Thanks for the enhancement.
fmelizard
  • Nov 22, 2015 12:11 AM UTC
I can confirm this is in the betas now. My little test workspace shows the new functionality in action -- I get 4 zip files, each with one feature, because I'm "fanning out" on the _creation_instance attribute.
badzip_1.fmw
  • Nov 22, 2015 2:17 AM UTC
Thanks for the enhancement and the demo workspace. I confirmed that it works fine for a folder-based format wirter (ESRISHAPE), file-based format writer (TEXTLINE) and the File Copy writer with this workspace:
fanout-zip-demo-b16133.fmwt
This has been released as part of FME 2016.1 . Visit http://www.safe.com/downloads to download and try it.
