New
Align Transformers by Port
Related products:FME Form
  • September 11, 2025
  • 52 views
ibruce
Forum|alt.badge.img+17
Currently, selected transformers can be positioned by right-clicking and selecting either Align or Spread.  Align provides the following options: Left, Middle, Right, Top, Center, or Bottom.  Spread provides the following options: Horizontal or Vertical.
I’d like to allow the user to align transformers by ports.  I often find myself trying (and failing) to align transformers so that the output of one transformer directly aligns with the input of another transformer.
mark2atsafe
Forum|alt.badge.img+59
Ha! You're like me. You like straight connection lines.
I find that it helps to use the control key (when moving a transformer to create an alignment) and then use the shift key too (when moving a transformer that is already aligned).
Still, I wouldn’t be against your idea! It would make it easier for me.
