Archived
Aliases for FME transformers near like the names used in OGC or SQL for similar
Related products:FME Form
  • January 22, 2016
  • 67 views
helmoet
Forum|alt.badge.img+8
***Note from Migration:***
Original Title was: Aliases for FME transformers near like the names used in OGC or SQL for similar functions
Hi guys,
I have a collegue that uses QGIS and Postgis a lot and FME Workbench a little. Every time he asks me “Hey, I’m looking for some function that does this, where is it in FME?”
Of course he should use FME Workbench a lot more often, be he came up with the idea to generate aliases for transformers that are near like the names used in OGC or SQL for the same function. Is that something where you could do something about?
erik_jan
Forum|alt.badge.img+26
  • January 22, 2016
Hello Helmoet.
I suggested something similar in this Idea:
https://knowledge.safe.com/content/idea/22186/open...
Erik Jan
gabriel_hirsch
Forum|alt.badge.img+15
You can create these aliases yourself pretty easy. Step by step instruction:
1. Close FME
2. Take a backup of the file fmesuite.fmx (found here, or equivalent: \\FME2018\\transformers\\fmesuite.fmx)
3. Open fmesuite.fmx in Notepad
4. Find the definition of the transformer you like to add an alias to.
5. If the transformer already has an alias (i.e. an old transformer name) just add a space after the last alias and add your alias. If the transformer doesn't have an alias, just add ALIASES: followed with your alias between the headings VERSION and CATEGORY.
6. Save the file and open FME and you can use your own created aliases.
7. Don't blame me if you screw things up here :-)
LizAtSafe
Forum|alt.badge.img+25
  • February 8, 2024
Updated idea statusGathering Interest→Archived
Idea merged into:
All the votes from this idea have been transferred.
