Open
Advanced FeatureColorSetter or FeatureStyler
Related products:Transformers
  • May 2, 2018 12:00 AM UTC
  • 67 views
salvaleonrp
Forum|alt.badge.img+23
Since the Inspector supports changing the drawing style of geometry it would be nice to have the FeatureColorSetter have opacity and width parameters.
mlupien
Forum|alt.badge.img+7
  • Jun 14, 2021 8:36 PM UTC
It would be also great if we can set an icon directly into the workbench for some multi point layers inspectors, it would be great !
jkr_wrk
Forum|alt.badge.img+37
  • Jun 22, 2021 1:42 PM UTC
Maybe it helps to know that FME inspectors listen to the fme_color and fme_fill_color parameter. You could set up an attributeCreator or attributeValueMapper to set the fme_color and fme_fill_color. Both can be set with an transparency setting I believe. A fme_width attribute could give it the last push.
Working with these attributes would mean that you can give attributes the styling that you want at the start or your workbench and all inspectors listen to your settings.
