Archived
Adding "Disconnect" to transformer context menu
Related products:FME Form
  • Sep 7, 2016 12:00 AM UTC
  • 31 views
lifalin2016
Forum|alt.badge.img+42
When you delete a transformer, the connection to and from it are automatically joined. If you want to "disconnect" a transformer, you have to do that yourself (or delete and recreate).
Wouldn't it be a simple feat to add a "Disconnect" option to the transformer context menu, releasing the transformer from its connections, which are automatically joined ? That would make moving transformers around in the workflow more easy and intuitive.
  • Sep 7, 2016 12:37 PM UTC
