Archived
Adding a disable/enable toggle in the Parameter Editor
Related products:FME Form
  • May 12, 2017
  • 56 views
While debugging it's handy to switch on/off Inspectors in the workspace.
Previously it was only possible with right-click and then pressing enable/disable.
But now with the Parameter Editor it saves the user a click, when adding the toggle button there.
The gain would be even bigger if this is possible for a collection of selected transformers and/or connectors.
  • May 12, 2017
You can select the Inspector (or whichever transformer you like) and toggle Disable/Enable by pressing Ctrl-E
  • May 12, 2017
You're right; you've actually remembered me (I am not a shortcut guy), but I see a nice place for it in the Editor as well.
