Archived
Add translation end date/time to the log
Related products:FME Form
  • May 3, 2016 12:00 AM UTC
  • 6 replies
  • 54 views
stevenjh
Forum|alt.badge.img+5
If you're having to rerun a translation multiple times or coming back to a workbench after working on something else I think it would be really handy if the translation log showed the date and time the job finished.
roland.martin
Forum|alt.badge.img+11
Does it help if you turn on "Log timestamp information"?
It's in Tools > Options > Translation > Log Settings.
stevenjh
  • May 6, 2016 2:41 AM UTC
That's one approach, drawback is the log isn't as nice to read when every line is prefixed with a timestamp .
kimo
Forum|alt.badge.img+10
  • May 16, 2016 11:24 PM UTC
I like pasting the log summary as annotation after I have finished the workspace. Then I have what is expected next time I need to edit the workbench. I currently need to add the date manually, so it would save me a step.
  • May 19, 2016 8:04 AM UTC
Here's a small workaround using a Python shutdown script. It will print the current timestamp in the log window (not in the log file) after the translation has terminated:
from datetime import datetime print datetime.now().strftime('Translation terminated on %Y-%m-%d %H:%M:%S')
David
kimo
  • Aug 14, 2018 2:05 AM UTC
Two year old idea and not implemented. Not very hard. Wasn't it good enough?
  • Aug 14, 2018 6:40 AM UTC
Not enough votes, perhaps?
