Is it possible to add the Tolerance parameter for the Spatial Filter as well? I have some issues with the 12th decimal number in an AutoCAD file. So, I was disappointed not to find this option for this Transformer.
Could get you the wrong results:
For example after applying a tolerance a point might be inside two separate polygons.
Not sure that is a good idea.
Surely not automatic, maybe as an option.
Already have an account? Login
