Released
Add support for writing ArcGIS Pro annotation
Related products:Integrations
  • September 2, 2021
  • 65 views
ranga_tolapi
Forum|alt.badge.img+11
It would be great if FME can also support writing ArcGIS Pro annotation.
True, agol does not yet support Annotations
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/arcgisonlinefeatures/quick_facts_arcgisonlinefeatures.htm
File geodatabase writer does support annotation
tcrossman
  • January 9, 2024
True enough, but I think the OP was getting at the version of the geodatabase written by FME [... OK, my bad. He was talking about AGOL, but a somewhat similar thing is going on with FME and Pro.] ... in which an annotation class is created and popupated. FME doesn't seem to create/write ArcGIS Pro annotation. It only creates 10.0 version annotation. I have a couple of cases where I need to uncheck the Annotation created with new features annotation property; however, I cannot do that in Pro for a 10.0 geodatabase. I have to use ArcGIS Desktop for that, and that won't be an option much longer. To use Pro to uncheck the property, I first have to upgrade the geodatabase in Pro. This is a real problem with the existing workflows.
LizAtSafe
Forum|alt.badge.img+25
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/geodatabase/GEODATABASE_FILE_writer.htm
