Archived
Add subfolder hierarchy parameter to readers.
Related products:Integrations
  • August 29, 2016
  • 11 replies
  • 52 views
taojunabc
Participant
FME can be specified on the reader reads all subfolders with **.
eg. C:Data***.shp, C:Data***.csv
But sumetimes, I don't need to read all the files in subfolders.
If I have the following folder structure.
If i set CSV reader dataset to C:Data***.csv.
Case 1
I want to read csv files in the [a1],[a1],[b1],[b1], But I don't want to read files in the [other] folder.
I hope to add a [Max Hierarchies to Read] parameters, control the maximum number of the subfolders hierarchies. In this case, this parameter can be set to 3 .
Case 2
I just want to read csv files in the specified hierarchy folder. eg.[a1*.csv],[a2*.csv].
I hope to add a [Specific Hierarchy to Read] parameters, control the number of specific subfolders hierarchy. In this case, this parameter can be set to 2 .
  • August 29, 2016
As a workaround, a combination of the PATH reader and FeatureReader may be useful. Assuming that "C:\\Data" is set to the Source Dataset for the PATH reader:
Path Filter for Case 1
{a1,b1}\\{b,}\\*.csv or {a1,a1\\b,b1,b1\\b}\\*.csv
Path Filter for Case 2
{a1,a2}\\*.csv
It might be better if path filter expressions could be used in source dataset setting for all file/folder-based format readers.
taojunabc
Participant
  • Participant
  • August 31, 2016
@takashi
Thaks your comment. I tested {a1,b1}\\{b,}\\*.csv, {a1,a1\\b,b1,b1\\b}\\*.csv and {a1,a2}\\*.csv. But get the same results as follows. I tested in FME 2016.1.1.0
extra characters after close-brace
Program Terminating
Translation FAILED.
  • August 31, 2016
Hi @taojunabc, my intention is to set a path filter expression to the 'Path Filter' parameter of the PATH reader, and then read matched CSV files with the FeatureReader. Did you configure your workspace like this?
Currently such a complex path filter expression cannot be used in other readers. I hope every reader for file/folder-based formats will accept any path filter expression through the Advanced Browser.
  • August 31, 2016
sorry, the Dataset setting for the FeatureReader in the previous screenshot was wrong. Updated the screenshot.
taojunabc
Participant
  • Participant
  • August 31, 2016
@takashi
Oh, sorry, I setted it to dataset.
I tested it on "path filter", It worked.
I found * parttens is allowed too. It is very convenience.
eg.{a1,b1}\\*\\*.csv, {*}\\{*}\\*.csv, *\\*\\*.csv
fmelizard
Forum|alt.badge.img+22
  • September 2, 2016
I'm curious if the \\ is being interpretted as an "escape" character and goofing up the file expansion. @takashi / @taojunabc -- if you tried {a1,b1}/{b,}/*.csv, {a1,a1/b,b1,b1/b}/*.csv does it make any difference? FME internally is very happy to use / as the file separator on Windows machines and \\ has the sometimes sad side effect of escaping what follows. (I don't have quick access to FME on Windows right now so can't check myself...)
  • September 2, 2016
Hi @daleatsafe, unfortunately slashes are also ineffective in the Dataset parameter setting for the CSV reader.
I tried adding a CSV reader with this setting (FME 2016.1.1, Windows 7).
However, the slashes have been changed to backslashes automatically and the comma within the path filter expression seems to be interpreted as a delimiter between paths.
Failed...
  • September 2, 2016
Interestingly, the reader feature type can be configured if you set the path filter through the Advanced Browser.
but the translation will fail.
fmelizard
  • September 2, 2016
I was thinking that maybe the advanced browser might be a way to get this in there...but then I can see where we get defeated later on. I think though we might be able to fix that for this case. I've alerted the appropriate authorities ( @GraemeAtSafe in particular...)
  • September 2, 2016
Thanks for your considerations. If every reader could handle path filter expressions like the PATH reader, it would be wonderful.
taojunabc
Participant
  • Participant
  • September 5, 2016
@daleatsafe,@takashi, Thanks for your comments.
As Takashi said, If every reader could handle path filter expressions like the PATH reader, it would be wonderful.
And I also think, If can privide [Max Hierarchies to Read] and [Specific Hierarchy to Read] parameters in advanced browser, May be more convenient to use.
