Archived
Add quick search filter to the String Editor and the Arithmetic Editor
Related products:FME Form
  • May 31, 2016 12:00 AM UTC
  • 39 views
taojunabc
Participant
When I use the string Editor or the Arithmetic Editor, The left side of the window will display the list of attributes, parameters, and functions. When I need to find a item ,especially a function. I often need through the scroll bar to find the function, if can add a quick filter function to the String Editor and the Arithmetic Editor, Will should be more quickly to find the item required.
This would be so good. Sometimes I have hundreds of attributes to scroll through to make sure I don't misspell it. Even if it just filtered FME Feature Attributes that would be great.
