Archived
Add options to webmap tiler
Related products:Transformers
  • Nov 27, 2017 12:00 AM UTC
  • 31 views
Would it be possible to add an option to filter out tiles that have only 0 or 255 values in it? I have been doing this with list range extractor, but I can only able to find tiles that have all 0 or 255 values, not ones that have all 0 or 255 values. It would be great to have this happen within the webmap tiler saving other steps in the chain.
paalped
Forum|alt.badge.img+11
  • Dec 7, 2017 11:48 AM UTC
import fme import fmeobjects # Template Function interface: # When using this function, make sure its name is set as the value of # the 'Class or Function to Process Features' transformer parameter def processFeature(feature): pass # Template Class Interface: # When using this class, make sure its name is set as the value of # the 'Class or Function to Process Features' transformer parameter class FeatureProcessor(object): def __init__(self): pass def input(self,feature): self.val = sum([int(i) for i in feature.getAttribute('_label').split(',')[:3]]) if self.val != 0 and self.val != 765: self.pyoutput(feature) def close(self): pass
This script is used with the RasterToPolygonCoercer
