Archived
Add Option to Turn OFF Accumulation Mode in FeatureMerger
Related products:Transformers
  • Feb 17, 2016 12:00 AM UTC
  • 6 replies
  • 74 views
Add Option to Turn OFF Accumulation Mode in FeatureMerger i case I don't want any attribute from supplier.
Problem occurs when there is just 1 element in the list of Requestor features and 2 elements in the list of Supplier features. Both lists have the same name.
After FeatureMerger with Accumulation Mode: Use Requestor.
The Second list element from Supplier will become the Second list element in Requestor
Which is quite annoying.
Final note:
Switching Requestor and Supplier port can provide a workaround, but In my case it does not give me the result I want and causing more problem than I already have.
My final solution is to always remove list from supplier before merging.
fmelizard
Forum|alt.badge.img+22
  • Feb 21, 2016 3:54 AM UTC
You can set the Feature Merge Type to Geometry instead of attributes if you don't want to merge attributes. But do you want some attributes merged and not others? Or is it just the list merging that is the issue?
  • Feb 22, 2016 9:18 AM UTC
I don't want to merge supplier attribute or Geomety, I just want use supplier as a reference or a filter to get only part of Requestor.
So it is just a list merging problem, I don't want to merge list members from supplier.
I can remove the list and all the attribute except ID from supplier first, but I can't always remember to do that.
So I want an option to 'Not Merge Supplier' as Accumulation Mode.
fmelizard
  • Feb 22, 2016 9:31 PM UTC
To say it another way, you do not want to merge anything at all. You're just checking if there are matching IDs from one stream of feature to another. So we'd have, in the "Feature Merge Type:" a new choice "Nothing" -- which woudl merge nothing from the suppliers onto the requestors?
  • Feb 23, 2016 7:37 AM UTC
Exactly!!!
geosander
Forum|alt.badge.img+7
  • Feb 23, 2016 11:25 AM UTC
Maybe I'm missing the point here, but couldn't you just use the Referenced and Unreferenced output ports for this? Keep in mind though that they output Supplier features, so you might want to swap the incoming features on the Requestor and Supplier ports depending on which set of features you need to check for matching IDs.
To illustrate the importance of what to connect to which input port, here's an example:
If you have more Suppliers than (matching) Requestors, Supplier features will leave both the Referenced and Unreferenced ports. If you swap the input (so more Requestors than Suppliers), nothing will come out of the Unreferenced port, but there will be Supplier features leaving the Referenced port and there are also Requestor features coming out of the NotMerged port.
  • Feb 23, 2016 4:38 PM UTC
sander_s, That's smart! I should have thought about that earlier.
But still, 'merging list element' is still a bug which bothers me most.
