Gathering Interest
Add Numeric Tolerance to ChangeDetector
Related products:FME Form
  • May 14, 2026 3:31 AM UTC
  • 5 replies
  • 125 views
brown3k
Forum|alt.badge.img+9
Due to the way decimals get stored one dataset may, for example, contain 1.7 and another 1.700000003. I can tell by looking that they’re the same as the data has no more than 4 decimal places.
It would be nice if the ChangeDetector had a tolerance for numbers. If I used 0.00001 for the above, as the difference between them is less than that, it would treat the data as unchanged.
PierreAtSafe
Forum|alt.badge.img+11
Updated idea statusNew→Open
j.botterill
Forum|alt.badge.img+69
  • May 19, 2026 10:37 AM UTC
Prior to changeDetector you may want to check the schema and the data type of the numerical attribute you are testing in changeDetector
attributeManager set data type for the numerical field in original and another in revised inputs going into chnageDetector
you can also set the precision of decimals using AttirbuteRounder on this numerical field
brown3k
  • May 22, 2026 1:49 AM UTC
I did solve it with AttributeRounders. It’d still be nice to have the ChangeDetector include a rounding tolerance instead.
todd_davis
Forum|alt.badge.img+23
  • May 26, 2026 1:05 AM UTC
I turn the numbers on the feature into a geometry and then compare the geometry with a small vector tolerance that the change detector allows (built that process around 7 years ago) . I found the attributerounder wasn’t good enough when I was dealing with a few million features everyday coming from sources with different precisions.
But yeah, a precision option would be great, but will certainly need a bit a of a rethink in the ChangeDetector UI.
LizAtSafe
Forum|alt.badge.img+26
  • Sep 3, 2026 12:38 AM UTC
Open→Gathering Interest
