Archived
Add NullAttributeMapper functionality in AttributeManager
Related products:FME Form
  • Nov 22, 2016 12:00 AM UTC
  • 58 views
erik_jan
Forum|alt.badge.img+26
The "Set Default Value" option in the AttributeManager only works for new attributes.
That forces me to use a NullAttributeMapper for each different default value (multiple attributes).
Adding this to the AttributeManager (Set a default value for Null and Empty attributes) would reduce the number of transformers in my workspace.
erik_jan
  • Dec 15, 2016 6:17 PM UTC
Just found out that this can be done in the AttributeManager using conditional values at the Set Value option ( If attributes not has a value, set to new value).
erik_jan
  • Dec 15, 2016 7:47 PM UTC
But the ability to set the default value for existing attributes without a value would save time setting up the conditional values.
