Archived
Add 'Global Search Envelope'
  • May 30, 2016
  • 66 views
Add 'Global Search Envelope' that can be applied to all the readers.
I was also looking for such a function and couldn't really find a method that worked for me online. Since I did stumble upon this post in my search, I will post the solution that worked for my case here. I'm not familiar with all the FME terms. I hope that the images make it clear enough.
It is based on a comment in this post.
In the (WFS) reader parameter list (green) there is the 'search envelope' parameter.
Right clicking one of the values results in three options: Edit Parameter value, Create User Parameter, and Link to user parameter.
First I created a User Parameter. (Create User Parameter)
Which looks like this.
The search envelope parameter from another reader can then be linked to to the created User Parameter. (Link to user parameter)
In the User Parameter list (purple) there is the Search Envelope User Parameter of the minimum X that I just created. Editing this parameter value (minimum X) will also change the values of the other minimum X that it is linked with.
If there is another solution to edit the search envelope of multiple readers at once I would like to hear them ;)
revesz
Forum|alt.badge.img+22
  • August 22, 2017
Even better, a central 'named search envelope'/'spatial bookmark' or similar would be really nice.
erik_jan
Forum|alt.badge.img+26
  • August 22, 2017
I like the idea of a named search envelope, similar to named connections, that can be re-used by multiple readers or even multiple workspaces.
  • August 23, 2017
