For documentation purposes it would be nice to have an option to export a list of objects that are contained in a project.
Preferred output format would be Excel, but another format could also work (text, csv).
Hi. At this point, we will not be adding this to FME Projects. As of FME 2023.1, in the UI you can now see the objects contained within the Project. You could also use the API to find this out if you wanted.
