Archived
Add "Enable/Disable Snap to Grid/Guides" Command to Context Menu on Canvas
Related products:FME Form
  • Jun 6, 2016 12:00 AM UTC
  • 110 views
Usually the "Snap to Grid/Guides" function is helpful to arrange objects orderly on the Canvas, but sometimes it's also annoying when move an object subtly. Although you can disable snapping through the "Grid and Guides" dialog, it might be convenient if the "Enable/Disable Snap to Grid/Guides" command would be added to the right-click menu on the Canvas (and/or a tool button), so that the user could switch enable/disable snapping quickly.
ekkischeffler
Forum|alt.badge.img+7
Hold down <Ctrl> while moving objects to move without snapping.
  • Jun 7, 2016 11:05 AM UTC
oops, I didn't know that. Thanks for the tip!
hannesz
Participant
  • Participant
  • Mar 1, 2021 7:58 AM UTC
Would like this one on the toolbar menu, so you are able to enable/disable the guides quickly.
