Archived
Add DRW Reader and Writer
Related products:Integrations
  • April 17, 2018
  • 46 views
pratap
Forum|alt.badge.img+12
fmelizard
Forum|alt.badge.img+22
  • May 1, 2018
Hi @pratap, could you provide a use case where you'd need to read from or write to DRW? Are you using it in CAD related workflows?
  • November 19, 2018
Hi, the National Archives would also like if this functionality could be added to FME. Our agency has received Micrografx files and requires a method to verify that the files are not corrupt and that the data can be viewed as expected and potentially converted to a better preservation format. We do not have a Micrografx application to open the files in their native environment since our agency receives permanent records only and not the applications used to view them.
Just an ability to read and translate from drw to dwg would be great. Read in DRW, make layer adjustments like in a dwg flow and write into a dwg file.
