Released
Add documentation for the autocad_info feature
Related products:FME Form
  • Jun 14, 2017 12:00 AM UTC
  • 5 replies
  • 56 views
gabriel_hirsch
Forum|alt.badge.img+15
In the Autodesk AutoCAD DWG/DXF reader you can choose to "Read Drawing System Variables" and a null feature of the type autocad_info is created. But there is no documentation of the attributes connected to the autocad_info feature.
As an AutoCAD user I can interpret the attributes but if you don't have AutoCAD it is pretty hard to know what is what. It would be better if there was a help section in the Autodesk AutoCAD DWG/DXF Reader/Writers documentation about the autocad_info feature and it's attributes. The current attributes that needs to be explained are the following: autocad_angbase, autocad_angdir, autocad_attmode,autocad_aunits, autocad_auprec, autocad_fillmode, autocad_insunits, autocad_latitude, autocad_longitude, autocad_lunits, autocad_luprec, autocad_projectname, autocad_proxygraphics, autocad_version
gabriel_hirsch
If I write this myself, will you include it in the help section?
fmelizard
Forum|alt.badge.img+22
  • Oct 12, 2017 6:09 AM UTC
Yes we will! But I'm sad to see this and will ask the team about it.
fmelizard
  • Oct 12, 2017 7:08 PM UTC
I have created a task for this, and it will be done shortly. Thank you for mentioning this.
fmelizard
  • Oct 16, 2017 6:05 AM UTC
gabriel_hirsch
This is very good news. Thank's alot! Safe Software rules!
