Archived
Add Custom Property Sets in DWG writing
Related products:FME FormIntegrationsTransformers
  • Aug 24, 2026 8:33 AM UTC
  • 41 views
vadis
Forum|alt.badge.img+14
It has been a while since we have DWG Autocad Civil3D Reader that can pick up Property Sets created in Autodesk native software as FME attributes. However, it has been quite a few cases where DWG deliverables or even templates need to be custom built to meet project requirements.
Having access to both FME and Autodesk ecosystems it is kinda possible to bridge the gap (real hassle) to achieve the above-mentioned task, however it would be awesome if this would be possible only in FME.
Suggestion:
  • Convert attributes established in FME to DWG Property Set schema which could be easily manipulated in workspace.
  • Property Sets include common data types, which could also be included in attribute/schema definition, where list manipulation with basic database operations would be heaven.
daveatsafe
Forum|alt.badge.img+24
  • Aug 24, 2026 5:07 PM UTC
Hi ​@vadis,
I think writing Property Sets would need to wait for a Civil 3D writer in FME. However, there may be a less convenient alternative using FME and Dynamo within Civil 3D. Please have a look at this article: https://support.safe.com/hc/en-us/articles/25407670868109-Integrating-FME-into-Dynamo-for-Revit-and-Civil-3D
andreaatsafe
Forum|alt.badge.img+17
Updated idea statusNew→Archived
Idea merged into:
All the votes from this idea have been transferred.
