Archived
Add 'Copy Number Start' Parameter to Cloner
Related products:FME Form
  • May 31, 2016 12:00 AM UTC
  • 53 views
Currently the copy number (_copynum) created by the Cloner always starts from 0. In some cases, the copy number will be used for parameters in the following transformers and there are cases it has to be a 1-based number. Although it's easy to increment the number, it might be better that the user could specify the starting number as a parameter of the Cloner, as same as the Counter.
  • Jun 1, 2016 6:59 AM UTC
If so, maybe also add this to the Creator and the ListExploder (any more?).
Forum|alt.badge.img+54
  • Jun 6, 2016 10:10 AM UTC
ModuloCounter
