Archived
Add "character encoding" importation to "Choice with Alias" user parameter
Related products:Integrations
  • September 8, 2017
  • 31 views
mathieu_ambrosy
Forum|alt.badge.img+5
The "Choice with Alias" user parameter is great because we are able to import coordinate systems, readers and writers.
Why not the ability to import "Character Encoding" items too ?
It would be great ie for a shapefile writer. We could import easily a selection of character encoding in a user parameter.
Mathieu.
rylanatsafe
Forum|alt.badge.img+14
@mathieu_ambrosy - Great idea! I think I may have found a "workaround"... emphasis on the quotation marks.
Step1: Create new User Parameter > Choice with Alias > Configuration > Import from Dataset.
Step2: Select CSV Reader, select the encodings.db (located in the FME installation folder).
Step3: Select Parameters and set "Delimiter Character" to | and set "Data Start Line" to 11. (Note: This value may be different for different FME versions...)
Step4: Select Continue and set "Import from" to Attribute Values.
Step5: Select Continue and set "Display Alias" to col2 and "Value" to col0. Select Import.
Step6. Voila! Now vote for this Idea because that was too much overhead.
Hopefully this is what you meant. If not, I had a fun journey with FME!
Please note that this is completely untested if this can actually be passed into Readers and Writers.
