Archived
Add button to save run parameters without running workspace
lifalin2016
Forum|alt.badge.img+41
A tiny addition.
My workspaces tends to quickly have many runtime parameters, and these are easiest maintained in the "Run with translation parameters" dialog. Unfortunately you either need to cancel, cancelling any changes, or press ok to save the changes _and_ run the workspace.
My tiny suggestion is adding an "Apply" button to save any changed parameter values without running the workspace.
Cheers
