Released
Add AWS Key Pairs as Resource
Related products:FME Form
  • June 3, 2016
  • 23 views
With the proliferation of the cloud and hybrid cloud solutions I propose the ability to add AWS key pairs as a resource (ie Web Connections) for use in AWS specific transformers. That way we don't need to bake them into the workbench when publishing to FME server.
This would also allow a single point of change for all (server/cloud) published workbenches if they need to be modified or revoked under IAM in the AWS console.
stewartatsafe
Forum|alt.badge.img+10
There is now an AWS web connection type. This allows you to add a key pair once and then reuse throughout FME Desktop. I talked about it here:
https://blog.safe.com/2016/11/sneak-peak-amazon-web-services-aws-improvements-2017/
