Normally when jobs are run, there is something identifiable about them, for example, they are a job for a tile, a postcode or a feature. If we could label a job with a name that was also visible in the web interface, then it would be easier to identify which job is currently processing, which ones are complete, etc.. Currently, the only way of identifying a job from the web interface is to drill into the summary page, find the parameters that were sent and interpret them to work out which item is being processed.
Archived
Add a job name to FME server jobs
