Open
Add a button to Label Points in Data Inspector/Data Preview
Related products:FME Form
j.botterill
Forum|alt.badge.img+69
When inspecting features, particularly identifying point geometries, I find myself wanting to visualise the Identifier attribute for alot of points, sometimes along lines and centre of polygons. Obviously desktop GIS have this functionality…. but
I’m asking to build on the Mark location option which already has a Label option. Can this same code be added under the Display Control, where users edit the styling of each dataset/layer
Data Inspection lacks functionality to add simple labels for a point dataset/layer
A workaround in workbench is to use LabelPointReplacer transformer to create text geom
So the updated UI will need Label section in the drawing style… and as pictured below
  • ability to select the Attribute Value column and make this the label text
  • the font and colour would be nice
  • label size (replacing font size?) may also be of assistance, though projected coordinates are likely needed to display in metres
Display Control drawing styles to include a Label
JennaKAtSafe
Forum|alt.badge.img+9
New→Open
JennaKAtSafe
Hi ​@j.botterill, I’m currently compiling a list usability improvements we can make to Data Inspector to improve the overall experience when inspecting your data. I will keep this one in mind.
Thank you for sharing!
j.botterill
  • April 24, 2026
HI ​@JennaKAtSafe just read your note. If you could also consider this very useful way to save preset/saved column selections… very handy for large schema and inspection/caching Visual Preview - Preset/Saved Column Selections | Community
